本文也發布在瀚思彼岸,另個學習HA的好地方。
先上圖:
這是我家的用電監控:
這是我家總電箱:
這是計算出每一條迴路可能的極限電流並清楚標示(總電箱、分電箱都一樣):
進入主題:
- 用原廠的上位機軟件設定各個PZEM-004T的address,本例設定為4、5、6
上位机软件 链接: https://pan.baidu.com/s/1bz0xh5PuSzBmZfRb-qPLPg**提取码: qi72**
參考原廠圖示接線,其實3.3V就可以了,不一定非要5V,三顆PZEM的接線並聯接到nodemcu即可。
ESPHOME的code,yaml裡面的電壓x2是因為台灣的家庭用電電壓是110V(單相三線),而本例是用來監控三台220V空調的所以x2,一般使用則不需要
一般家用通常可能只會監控入戶的兩條火線,則86明盒的大小還蠻適合的,所有零組件剛剛好能放進去:
device_name: energy-ac46
platform: ESP8266
board: nodemcuv2
baud_rate: 0 # (UART logging interferes with pzem)
level: DEBUG
#hardware_uart: uart1
password: !secret wifi_pw
ssid: ${device_name}_Fallback
#manual_ip:
#static_ip: 192.168.200.111
#gateway: 192.168.200.254
#subnet: 255.255.255.0
- tx_pin: D1
rx_pin: D2
baud_rate: 9600
stop_bits: 1
modbus:
- platform: status
- platform: pzemac
energy:
- multiply: 0.002
unit_of_measurement: kWh
accuracy_decimals: 1
current:
voltage:
- multiply: 2
frequency:
power_factor:
power:
- multiply: 2
accuracy_decimals: 0
update_interval: never
address: 4
- platform: pzemac
energy:
- multiply: 0.002
current:
voltage:
- multiply: 2
frequency:
power_factor:
power:
- multiply: 2
address: 5
- platform: pzemac
energy:
- multiply: 0.002
current:
voltage:
- multiply: 2
frequency:
power_factor:
power:
- multiply: 2
address: 6
- platform: total_daily_energy
power_id: power_ac4
icon: mdi:counter
- multiply: 0.001
power_id: power_ac5
icon: mdi:counter
- multiply: 0.001
power_id: power_ac6
icon: mdi:counter
- multiply: 0.001
icon: mdi:counter
device_class: energy
state_class: measurement
return id(energy_ac4_daily).state + id(energy_ac5_daily).state + id(energy_ac6_daily).state ;
# return id(energy1_all_daily).raw_state + id(energy2_all_daily).raw_state
#SLOW SENSORS FOR HOME ASSISTANT#
- platform: template #########################
if (id(current_ac4).state) {
return (id(current_ac4).state);
} else {
return 0;
unit_of_measurement: A
icon: "mdi:alpha-a-circle"
if (id(current_ac5).state) {
return (id(current_ac5).state);
} else {
return 0;
if (id(current_ac6).state) {
return (id(current_ac6).state);
} else {
return 0;
- platform: homeassistant
- platform: uart
data: [0x01, 0x42, 0x80, 0x11]
interval:
- interval: 5s
- lambda: 'id(pzemac4).update();'
- delay: 150ms
- lambda: 'id(pzemac5).update();'
- delay: 150ms
- lambda: 'id(pzemac6).update();'
