以下為NR洗衣機提醒簡易版
請大家自行匯入取用
[{“id”:“d7f2baf39c2db909”,“type”:“server-state-changed”,“z”:“505b96f2f0accced”,“name”:“洗衣機啟動”,“server”:“91a78be.0d63e78”,“version”:4,“exposeToHomeAssistant”:false,“haConfig”:[{“property”:“name”,“value”:“”},{“property”:“icon”,“value”:“”}],“entityidfilter”:“sensor.xi_yi_ji_dian_yuan_power”,“entityidfiltertype”:“exact”,“outputinitially”:false,“state_type”:“str”,“haltifstate”:“10”,“halt_if_type”:“num”,“halt_if_compare”:“gt”,“outputs”:2,“output_only_on_state_change”:false,“for”:0,“forType”:“num”,“forUnits”:“minutes”,“ignorePrevStateNull”:false,“ignorePrevStateUnknown”:false,“ignorePrevStateUnavailable”:false,“ignoreCurrentStateUnknown”:false,“ignoreCurrentStateUnavailable”:false,“outputProperties”:[{“property”:“payload”,“propertyType”:“msg”,“value”:“”,“valueType”:“entityState”},{“property”:“data”,“propertyType”:“msg”,“value”:“”,“valueType”:“eventData”},{“property”:“topic”,“propertyType”:“msg”,“value”:“”,“valueType”:“triggerId”}],“x”:100,“y”:100,“wires”:[[“6a5388607397479e”],]},{“id”:“6a5388607397479e”,“type”:“ha-wait-until”,“z”:“505b96f2f0accced”,“name”:“0W”,“server”:“91a78be.0d63e78”,“version”:2,“outputs”:1,“entityId”:“sensor.xi_yi_ji_dian_yuan_power”,“entityIdFilterType”:“exact”,“property”:“state”,“comparator”:“lte”,“value”:“0”,“valueType”:“num”,“timeout”:“0”,“timeoutType”:“num”,“timeoutUnits”:“minutes”,“checkCurrentState”:true,“blockInputOverrides”:true,“outputProperties”:,“x”:270,“y”:100,“wires”:[[“b4fb502207678c7d”]]},{“id”:“7f949cfa19f21555”,“type”:“api-current-state”,“z”:“505b96f2f0accced”,“name”:“0W”,“server”:“91a78be.0d63e78”,“version”:3,“outputs”:2,“halt_if”:“0”,“halt_if_type”:“num”,“halt_if_compare”:“lte”,“entity_id”:“sensor.xi_yi_ji_dian_yuan_power”,“state_type”:“str”,“blockInputOverrides”:false,“outputProperties”:[{“property”:“payload”,“propertyType”:“msg”,“value”:“”,“valueType”:“entityState”},{“property”:“data”,“propertyType”:“msg”,“value”:“”,“valueType”:“entity”}],“for”:0,“forType”:“num”,“forUnits”:“minutes”,“override_topic”:false,“state_location”:“payload”,“override_payload”:“msg”,“entity_location”:“data”,“override_data”:“msg”,“x”:110,“y”:180,“wires”:[[“da0102049454a198”],]},{“id”:“da0102049454a198”,“type”:“line-notify”,“z”:“505b96f2f0accced”,“name”:“洗衣機”,“message”:“衣服洗好了!”,“contentType”:“sticker”,“imageThumbnail”:“”,“imageUrl”:“”,“sticker”:“default”,“stickerPackageId”:“8525”,“stickerId”:“16581290”,“silent”:false,“creds”:“283cfad4.bd0936”,“x”:250,“y”:180,“wires”:[[“267a667642724a63”,“8d537b8e20f46ce7”]]},{“id”:“267a667642724a63”,“type”:“api-current-state”,“z”:“505b96f2f0accced”,“name”:“確認Amanda在家”,“server”:“91a78be.0d63e78”,“version”:3,“outputs”:2,“halt_if”:“home”,“halt_if_type”:“str”,“halt_if_compare”:“is”,“entity_id”:“person.amanda”,“state_type”:“str”,“blockInputOverrides”:false,“outputProperties”:[{“property”:“payload”,“propertyType”:“msg”,“value”:“”,“valueType”:“entityState”},{“property”:“data”,“propertyType”:“msg”,“value”:“”,“valueType”:“entity”}],“for”:0,“forType”:“num”,“forUnits”:“minutes”,“override_topic”:false,“state_location”:“payload”,“override_payload”:“msg”,“entity_location”:“data”,“override_data”:“msg”,“x”:450,“y”:180,“wires”:[[“f5de6daece054cee”],]},{“id”:“f5de6daece054cee”,“type”:“api-call-service”,“z”:“505b96f2f0accced”,“name”:“音量70%”,“server”:“91a78be.0d63e78”,“version”:5,“debugenabled”:false,“domain”:“media_player”,“service”:“volume_set”,“areaId”:,“deviceId”:,“entityId”:[“media_player.ke_ting_2”],“data”:“{"volume_level": "0.7"}”,“dataType”:“json”,“mergeContext”:“”,“mustacheAltTags”:false,“outputProperties”:,“queue”:“none”,“x”:640,“y”:180,“wires”:[[“38a70e484203ea9f”]]},{“id”:“38a70e484203ea9f”,“type”:“api-call-service”,“z”:“505b96f2f0accced”,“name”:“衣服洗好”,“server”:“91a78be.0d63e78”,“version”:5,“debugenabled”:false,“domain”:“tts”,“service”:“azure_cognitive_speech_say”,“areaId”:,“deviceId”:,“entityId”:[“media_player.ke_ting_2”],“data”:“{"message": "衣服洗好了"}”,“dataType”:“json”,“mergeContext”:“”,“mustacheAltTags”:false,“outputProperties”:,“queue”:“none”,“x”:640,“y”:100,“wires”:[]},{“id”:“b4fb502207678c7d”,“type”:“stoptimer2”,“z”:“505b96f2f0accced”,“duration”:“5”,“durationType”:“num”,“units”:“Second”,“payloadtype”:“num”,“payloadval”:“0”,“name”:“5S”,“x”:410,“y”:100,“wires”:[[“7f949cfa19f21555”],]},{“id”:“8d537b8e20f46ce7”,“type”:“api-current-state”,“z”:“505b96f2f0accced”,“name”:“確認Chris在家”,“server”:“91a78be.0d63e78”,“version”:3,“outputs”:2,“halt_if”:“home”,“halt_if_type”:“str”,“halt_if_compare”:“is”,“entity_id”:“person.sweethome”,“state_type”:“str”,“blockInputOverrides”:false,“outputProperties”:[{“property”:“payload”,“propertyType”:“msg”,“value”:“”,“valueType”:“entityState”},{“property”:“data”,“propertyType”:“msg”,“value”:“”,“valueType”:“entity”}],“for”:0,“forType”:“num”,“forUnits”:“minutes”,“override_topic”:false,“state_location”:“payload”,“override_payload”:“msg”,“entity_location”:“data”,“override_data”:“msg”,“x”:440,“y”:240,“wires”:[[“f5de6daece054cee”],]},{“id”:“91a78be.0d63e78”,“type”:“server”,“name”:“Home Assistant”,“version”:5,“addon”:true,“rejectUnauthorizedCerts”:true,“ha_boolean”:“y|yes|true|on|home|open”,“connectionDelay”:true,“cacheJson”:true,“heartbeat”:false,“heartbeatInterval”:“30”,“areaSelector”:“friendlyName”,“deviceSelector”:“friendlyName”,“entitySelector”:“friendlyName”,“statusSeparator”:"at: ",“statusYear”:“hidden”,“statusMonth”:“short”,“statusDay”:“numeric”,“statusHourCycle”:“h23”,“statusTimeFormat”:“h:m”,“enableGlobalContextStore”:true},{“id”:“283cfad4.bd0936”,“type”:“linetoken”,“name”:“wash machine”}]
以上為本次分享內容
