EspHome_ESP-01S無線模塊製作wifi版的4路點動無線開關
EspHome使用ESP-01S無線模塊利用GPIO1、GPIO2 、GPIO3和、GPIO0 腳位,連接四個實體復位開關製作”具有zigbee無線開關”的single, double, triple, quadruple, many and long模式,可以用node-red與ha內的自動化達成wifi版的無線開關
# https://community.home-assistant.io/t/esphome-sonoff-and-external-switches/114512/6
#4路
  device_name: "button"
  friendly_name: BB8-4路點動按鈕
  name_add_mac_suffix: true
#name_add_mac_suffix 添加mac位址在name後面
#不需要再name後面增加mac位址需把此行註解掉
#缺點 ota時需產出bin並登入web頁面更新
#優點 每個設備加入時都會是不同的id方便辨識
esp8266:                      # 指定使用 ESP8266 平台
  board: esp01_1m             # 设置开发板型号为 ESP-01/01S (1MB Flash)
  restore_from_flash: true    # 启用从 Flash 恢复状态(断电重启后,保留之前的状态)
preferences:
 flash_write_interval: 10s
packages:
  device_web: !include templates/device_web.yaml
## Buton 01
      number: GPIO2
      - delayed_on: 50ms
      - delayed_off: 50ms
    on_multi_click:   # 這種設定通常用來判斷「單擊」或「短按」的行為: ✅ 防止誤觸:確保使用者真的短按了按鍵,而不是因為抖動或誤觸。
      - timing:
          - ON for at most 1s
          - OFF for at least 250ms  # 減少 OFF 時間,提高識別成功率 預設400ms
          - text_sensor.template.publish:
              state: "button_pressed" # 這行代碼是用來更新 text_sensor(文字傳感器)的狀態值。
          - delay: 50ms
              state: "button_01_single"
          - delay: 2s # 增加 2 秒延遲
              state: "" # 重設狀態
      - timing:
          - ON for at most 1s
          - OFF for at most 399ms
          - ON for at most 1s
          - OFF for at least 400ms
          - delay: 50ms
              state: "button_01_double"
              state: "" # 重設狀態
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - delay: 50ms
              state: "button_01_triple"
              state: "" # 重設狀態
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - delay: 50ms
              state: "button_01_quadruple"
              state: "" # 重設狀態
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - ON for at least 400ms
          - delay: 50ms
              state: "button_01_many"
              state: "" # 重設狀態
      - timing:
          - ON for at least 2s
          - delay: 50ms
              state: "button_01_long"
              state: "" # 重設狀態
## Buton 02
      number: GPIO0
      - delayed_on: 50ms
      - delayed_off: 50ms
    on_multi_click:
      - timing:
          - ON for at most 1s
          - delay: 50ms
              state: "button_02_single"
              state: "" # 重設狀態
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - delay: 50ms
              state: "button_02_double"
              state: "" # 重設狀態
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - delay: 50ms
              state: "button_02_triple"
              state: "" # 重設狀態
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - delay: 50ms
              state: "button_02_quadruple"
              state: "" # 重設狀態
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - delay: 50ms
              state: "button_02_many"
              state: "" # 重設狀態
      - timing:
          - delay: 50ms
              state: "button_02_long"
              state: "" # 重設狀態
## Buton 03
      number: GPIO3
      - delayed_on: 50ms
      - delayed_off: 50ms
    on_multi_click:
      - timing:
          - ON for at most 1s
          - delay: 50ms
              state: "button_03_single"
              state: "" # 重設狀態
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - delay: 50ms
              state: "button_03_double"
              state: "" # 重設狀態
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - delay: 50ms
              state: "button_03_triple"
              state: "" # 重設狀態
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - delay: 50ms
              state: "button_03_quadruple"
              state: "" # 重設狀態
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - delay: 50ms
              state: "button_03_many"
              state: "" # 重設狀態
      - timing:
          - delay: 50ms
              state: "button_03_long"
              state: "" # 重設狀態
## Buton 04
      number: GPIO1
      - delayed_on: 50ms
      - delayed_off: 50ms
    on_multi_click:
      - timing:
          - ON for at most 1s
          - delay: 50ms
              state: "button_04_single"
              state: "" # 重設狀態
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - delay: 50ms
              state: "button_04_double"
              state: "" # 重設狀態
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - delay: 50ms
              state: "button_04_triple"
              state: "" # 重設狀態
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - delay: 50ms
              state: "button_04_quadruple"
              state: "" # 重設狀態
      - timing:
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - ON for at most 1s
          - delay: 50ms
              state: "button_04_many"
              state: "" # 重設狀態
      - timing:
          - delay: 50ms
              state: "button_04_long"
              state: "" # 重設狀態
    unit_of_measurement: '%'
    accuracy_decimals: 0
    icon: "mdi:wifi"
        if (id( wifi_1).state < -92.0)
          return 100.0;
        if (id( wifi_1).state > -21.0)
          return 1.0;
        else
          return round(( -0.0154 * id( wifi_1).state * id( wifi_1).state ) - ( 0.3794 * id( wifi_1).state ) + 98.182 );
    icon: "mdi:light-switch"
      return {};
      name: ${device_name} IP Address
      icon: "mdi:ip-network"
      icon: "mdi:signal-variant"
      name: ${device_name} Mac Wifi Address
      icon: "mdi:wifi-marker"
status_led:
    number: GPIO13
    inverted: true
請問5V是用何種電池供電的
使用110V轉5V的充電接頭,5V1A即可
