Sonoff M5 Esphome Yaml Share
感謝Mini 以及Simon大大提供方式
解決雙鍵右鍵指示燈不亮的問題
並加上指示燈背光微亮設定
以下為個人常用的設定分享
單鍵
  devicename: m5-1button
  upper_devicename: "M5 1Button"
  friendly_name: M5 1Button
  on_boot:
      - light.dim_relative:
          relative_brightness: 20%
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
# Enable Home Assistant API
#  password: "your-ota-password"
  password: !secret wifi_password
  # Enable fallback hotspot (captive portal) in case wifi connection fails
    ssid: "M5-1Button"
    password: "87654321"
# Example configuration entry
# Uptime
# WiFi Signal
    name: ${friendly_name} WiFi Signal
status_led:
    number: GPIO5
    inverted: true
    pin: 23
    on_turn_on:
      - output.turn_on: buttonlight
    on_turn_off:
      - output.turn_off: buttonlight
output:
  - platform: ledc
    pin: 18
    frequency: 1000 Hz
    pin: 19
light:
  - platform: monochromatic
    output: backlight_ledc
      number: 0
    on_press:
      - switch.toggle: relay_1
雙鍵
  devicename: m5-2button
  upper_devicename: "M5 2Button"
  friendly_name: M5 2Button
  on_boot:
          relative_brightness: 30%
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
    ssid: "M5-2Button"
# Uptime
# WiFi Signal
status_led:
    number: GPIO5
    inverted: true
    pin: 23
    pin: 19
    on_turn_on:
      - output.turn_on: buttonlight_2
    on_turn_off:
      - output.turn_off: buttonlight_2
output:
  - platform: ledc
    pin: 18
    frequency: 1000 Hz
    pin: 22
light:
      number: 4
    on_press:
      number: 15
    on_press:
      - switch.toggle: relay_2
三鍵
  devicename: m5-3button
  upper_devicename: "M5 3Button"
  friendly_name: M5 3Button
  on_boot:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
    ssid: "M5-3Button"
# Uptime
# WiFi Signal
status_led:
    number: GPIO5
    inverted: true
    pin: 23
    pin: 19
    pin: 22
output:
  - platform: ledc
    pin: 18
    frequency: 1000 Hz
light:
      number: 4
    on_press:
      number: 0
    on_press:
      number: 15
    on_press:
      - switch.toggle: relay_3
