[分享] 16鍵鍵盤 (ESPHome)
鍵盤主體為 4x4 矩陣鍵盤 與 ESP32-C3 開發板,使用 HA + ESPhome 系統,wifi 通訊,USB 供電
一次能按單個按鍵,每個按鍵可有多種按鍵事件(single / double / hold / …)
電路接線
開發板 GPIO8 有連接 LED 使用,因此圖中鍵盤第四腳跨接至上方 GPIO4
開發板 GPIO9 有連接 Boot Button,預計不會使用,因此也拿來連接鍵盤使用
desktop-keypad.yaml
  device_name: "desktop-keypad"
  friendly_name: 桌面開關16鍵
packages:
  device_web: !include templates/device_web.yaml
esp32:
  board: esp32-c3-devkitm-1
matrix_keypad:
  rows:
    - pin: GPIO21
    - pin: GPIO20
    - pin: GPIO10
    - pin: GPIO9
  columns:
    - pin: GPIO4
    - pin: GPIO7
    - pin: GPIO6
    - pin: GPIO5
  - <<: !include { file: common/keypad/matrix_keypad_button.yaml, vars: { num: 1, row: 0, col: 0} }
  - <<: !include { file: common/keypad/matrix_keypad_button.yaml, vars: { num: 2, row: 0, col: 1} }
  - <<: !include { file: common/keypad/matrix_keypad_button.yaml, vars: { num: 3, row: 0, col: 2} }
  - <<: !include { file: common/keypad/matrix_keypad_button.yaml, vars: { num: 4, row: 0, col: 3} }
  - <<: !include { file: common/keypad/matrix_keypad_button.yaml, vars: { num: 5, row: 1, col: 0} }
  - <<: !include { file: common/keypad/matrix_keypad_button.yaml, vars: { num: 6, row: 1, col: 1} }
  - <<: !include { file: common/keypad/matrix_keypad_button.yaml, vars: { num: 7, row: 1, col: 2} }
  - <<: !include { file: common/keypad/matrix_keypad_button.yaml, vars: { num: 8, row: 1, col: 3} }
  - <<: !include { file: common/keypad/matrix_keypad_button.yaml, vars: { num: 9, row: 2, col: 0} }
  - <<: !include { file: common/keypad/matrix_keypad_button.yaml, vars: { num: 10, row: 2, col: 1} }
  - <<: !include { file: common/keypad/matrix_keypad_button.yaml, vars: { num: 11, row: 2, col: 2} }
  - <<: !include { file: common/keypad/matrix_keypad_button.yaml, vars: { num: 12, row: 2, col: 3} }
  - <<: !include { file: common/keypad/matrix_keypad_button.yaml, vars: { num: 13, row: 3, col: 0} }
  - <<: !include { file: common/keypad/matrix_keypad_button.yaml, vars: { num: 14, row: 3, col: 1} }
  - <<: !include { file: common/keypad/matrix_keypad_button.yaml, vars: { num: 15, row: 3, col: 2} }
  - <<: !include { file: common/keypad/matrix_keypad_button.yaml, vars: { num: 16, row: 3, col: 3} }
event:
    device_class: button
    event_types:
      - "button_1_single"
      - "button_1_double"
      - "button_1_hold"
      - "button_2_single"
      - "button_2_double"
      - "button_2_hold"
      - "button_3_single"
      - "button_3_double"
      - "button_3_hold"
      - "button_4_single"
      - "button_4_double"
      - "button_4_hold"
      - "button_5_single"
      - "button_5_double"
      - "button_5_hold"
      - "button_6_single"
      - "button_6_double"
      - "button_6_hold"
      - "button_7_single"
      - "button_7_double"
      - "button_7_hold"
      - "button_8_single"
      - "button_8_double"
      - "button_8_hold"
      - "button_9_single"
      - "button_9_double"
      - "button_9_hold"
      - "button_10_single"
      - "button_10_double"
      - "button_10_hold"
      - "button_11_single"
      - "button_11_double"
      - "button_11_hold"
      - "button_12_single"
      - "button_12_double"
      - "button_12_hold"
      - "button_13_single"
      - "button_13_double"
      - "button_13_hold"
      - "button_14_single"
      - "button_14_double"
      - "button_14_hold"
      - "button_15_single"
      - "button_15_double"
      - "button_15_hold"
      - "button_16_single"
      - "button_16_double"
      - "button_16_hold"
- platform: matrix_keypad
  keypad_id: mykeypad
  row: $row
  col: $col
  internal: true
  on_multi_click:
    - timing:
        - ON for at most 0.6s
        - OFF for at most 0.3s
        - OFF for at least 0.1s
      invalid_cooldown: 100ms
        - event.trigger: { id: action, event_type: "button_${num}_double" }
    - timing:
        - OFF for at least 0.3s
        - event.trigger: { id: action, event_type: "button_${num}_single" }
    - timing:
        - ON for at least 0.6s
        - event.trigger: { id: action, event_type: "button_${num}_hold" }
device_web.yaml 為 esphome, wifi, ota, api, web_server … 等基本配置(略)
HA - automations.yaml
- id: 'desktop-keypad'
  alias: 桌面開關16鍵
  mode: parallel
  max: 10
  triggers:
    - trigger: event.received
      target:
        entity_id: event.desktop_keypad_action
      options:
        event_type:
          - button_1_single
  conditions: []
  actions:
    - choose:
        - conditions:
            - condition: trigger
            - action: script.set_an_alarm_to_take_out_the_trash
其它矩陣鍵盤案例
參考資訊
