- 還有一個腳位(GPIO3),就接上點動開關,控制螢幕使用
Esphome~Diy的材料
1、DS18B20溫度探頭(改成3.5mm接頭)
2、0.96Oled螢幕
3、5v轉3.3v降壓模塊
4、Esp-01s晶片
5、防水盒
6、3.5mm公母插座
7、Type-C母座
8、12mm金屬按鈕自重式點動開關
※所有模塊均可拔插抽換(含oled螢幕)方便日後維修
device_name: "ds18b20-ssd1306" # 裝置名稱代稱,可重複使用
friendly_name: ds18b20螢幕版 # 裝置顯示名稱
packages:
device_web: !include templates/device_web.yaml # 網頁管理功能封裝模組
board: esp01_1m # 使用 ESP-01 1MB Flash 板子
name_add_mac_suffix: true
on_boot:
- lambda: |-
id(my_display).turn_off(); // 開機時關閉 OLED 顯示器
i2c:
sda: GPIO0 # I2C 資料線(OLED)
scl: GPIO2 # I2C 時鐘線(OLED)
scan: true # 啟用自動掃描 I2C 裝置(方便 debug)
one_wire:
pin: GPIO1 # DS18B20 感測器接在 GPIO1(TX 腳)
globals:
- id: last_temp
type: float
restore_value: no
initial_value: '0.0' # 儲存上一次溫度,用來比較是否變化
number:
name: "螢幕觸發溫度變化閾值" # 可透過 HA 調整溫度變化觸發門檻
optimistic: true
min_value: 0.01
max_value: 5.0
step: 0.01
initial_value: 0.1 # 預設變動大於 0.1°C 才觸發
name: "螢幕顯示時間(秒)" # 可透過 HA 調整螢幕顯示時間
optimistic: true
min_value: 5
max_value: 300
step: 5
initial_value: 30 # 預設亮 30 秒後關閉
## Button 01
number: GPIO3
- delayed_on: 50ms
- delayed_off: 50ms
on_multi_click:
- timing:
- ON for at most 1s
- OFF for at least 400ms
- text_sensor.template.publish:
state: "button_pressed"
- delay: 50ms
state: "button_01_single"
- delay: 2s # 增加 2 秒延遲
state: "" # 重設狀態
- timing:
- ON for at most 1s
- OFF for at most 399ms
- ON for at most 1s
- delay: 50ms
state: "button_01_double"
state: "" # 重設狀態
- timing:
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- delay: 50ms
state: "button_01_triple"
state: "" # 重設狀態
- timing:
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- delay: 50ms
state: "button_01_quadruple"
state: "" # 重設狀態
- timing:
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at most 1s
- ON for at least 400ms
- delay: 50ms
state: "button_01_many"
state: "" # 重設狀態
- timing:
- ON for at least 2s
- delay: 50ms
state: "button_01_long"
state: "" # 重設狀態
- platform: dallas_temp
address: 0x1b00000087d9f728 # DS18B20 感測器唯一地址
name: "Temperature" # 顯示名稱
icon: "mdi:thermometer"
update_interval: 30s # 每 30 秒讀取一次溫度
on_value:
- lambda: |-
// 如果溫度變化大於設定門檻,則開啟螢幕並重新啟動計時
if (abs(id(R1).state - id(last_temp)) > id(temp_delta_threshold).state) {
id(last_temp) = id(R1).state;
id(my_display).turn_on();
id(oled_off_timer).execute();
name: "WiFi Signal Sensor" # 顯示 WiFi 訊號強度(數值)
name: Uptime Sensor # 顯示運作時間(秒)
id: wifi_1 # 另存一份 WiFi 訊號,用於百分比轉換計算
name: Wifi signal # 轉換 WiFi 訊號為百分比顯示
unit_of_measurement: '%'
accuracy_decimals: 0
icon: "mdi:wifi"
if (id(wifi_1).state < -92.0)
return 100.0;
if (id(wifi_1).state > -21.0)
return 1.0;
return round(( -0.0154 * id(wifi_1).state * id(wifi_1).state )
- ( 0.3794 * id(wifi_1).state )
+ 98.182 );
font:
- file: "arial.ttf"
size: 16 # 小字體(顯示時間)
- file: "arialbd.ttf"
size: 20 # 中字體(保留)
size: 38 # 大字體(顯示溫度)
display:
- platform: ssd1306_i2c
model: SSD1306_128X64
address: 0x3C
pages:
- id: page1
it.strftime(64, 0, id(font1), TextAlign::TOP_CENTER, "%Y/%m/%d %H:%M", id(esptime).now());
it.printf(64, 56, id(font3), TextAlign::BASELINE_CENTER, "%.1f°C", id(R1).state);
script:
- id: oled_off_timer
mode: restart # 每次執行都重新倒數
- delay: !lambda 'return (uint32_t)(id(oled_on_duration).state * 1000);' # 根據設定延遲秒數
- lambda: id(my_display).turn_off(); # 倒數結束後關閉螢幕
- platform: sntp
timezone: Asia/Taipei # 使用台北時間
name: "Restart" # 重啟按鈕(可從 HA 操作)
restore_mode: ALWAYS_OFF # 開機預設關閉
lambda: |- # 回傳目前狀態
return id(my_display).is_on();
turn_on_action:
- lambda: id(my_display).turn_on();
turn_off_action:
icon: "mdi:light-switch"
return {};
lambda: 'return {WiFi.localIP().toString().c_str()};'
name: IP Address # 顯示 IP 位址
icon: "mdi:ip-network"
name: Connected SSID # 顯示連線的 SSID
icon: "mdi:signal-variant"
name: Mac Wifi Address # 顯示 MAC 位址
icon: "mdi:wifi-marker"
name: "ESPHome Version" # 顯示目前韌體版本
interval:
- interval: 1s
- lambda: |-
static bool display_timer_active = false;
static uint32_t display_timer_start = 0;
if (id(buttons).state == "button_01_single" && !display_timer_active) {
ESP_LOGD("screen", "button_01_single 按下,螢幕開啟");
display_timer_start = millis();
display_timer_active = true;
if (display_timer_active && millis() - display_timer_start > 15000) {
ESP_LOGD("screen", "15秒到,螢幕關閉");
id(buttons).publish_state(""); // 重置狀態,避免重複觸發
