DIY Portable ESPHome Power Usage Monitor
# https://github.com/PricelessToolkit/PowerMeter/tree/main
# https://www.youtube.com/watch?v=dMA6r-ai6mg
# https://github.com/PricelessToolkit/PowerMeter/blob/main/ESPHome/pmeter.yaml
# https://github.com/PricelessToolkit/PowerMeter/blob/main/PresenceDetection/wifipresencedetection.yaml
# 螢幕版http://psenyukov.ru/%D0%BC%D0%BE%D0%BD%D0%B8%D1%82%D0%BE%D1%80%D0%B8%D0%BD%D0%B3-%D1%8D%D0%BB%D0%B5%D0%BA%D1%82%D1%80%D0%BE%D1%8D%D0%BD%D0%B5%D1%80%D0%B3%D0%B8%D0%B8-%D1%81-%D0%BF%D0%BE%D0%BC%D0%BE%D1%89%D1%8C%D1%8E/
# https://www.youtube.com/watch?v=Cv20o5_Su5I
# Portable Power Meter (Optimized Final Version)
device_name: portable-power-meter
friendly_name: pmeter單獨電力監測移動版
on_boot:
priority: -10
- delay: 3s
- lambda: |-
id(my_display).turn_off();
board: d1_mini
framework:
version: latest
restore_from_flash: false
# Logging
baud_rate: 0
level: ERROR
# Home Assistant API
reboot_timeout: 0s
# OTA 更新
- platform: esphome
# Web 伺服器
# WiFi 設定
min_auth_mode: WPA2
ssid: "${device_name}_AP"
password: !secret ap_password
# 全域變數
globals:
- id: oled_timeout_sec
type: int
initial_value: '30' # OLED 亮 30 秒後自動關閉
# 按鈕:系統 Restart
# I2C / UART / Modbus
i2c:
sda: D2
scl: D1
scan: true
- id: ubus1
tx_pin: GPIO1 # TX → PZEM RX
rx_pin: GPIO3 # RX → PZEM TX
baud_rate: 9600
stop_bits: 1
modbus:
- id: modbus1
uart_id: ubus1
# 時間同步(HA + SNTP)
- platform: homeassistant
on_time:
- seconds: 59
minutes: 59
hours: 23
- sensor.template.publish:
state: !lambda return id(PZEM004T_Move_ENERGY).state;
- platform: sntp
timezone: Asia/Taipei
# WiFi 自動重連開關 + OLED 開關
restore_mode: ALWAYS_OFF
return id(my_display).is_on();
turn_on_action:
- lambda: id(my_display).turn_on();
turn_off_action:
- lambda: id(my_display).turn_off();
- platform: uart
uart_id: ubus1
name: "Move 110V Reset Energy"
data: [0x01, 0x42, 0x80, 0x11]
# 按鈕:單擊亮屏、雙擊關屏(特別最佳化過)
number: GPIO14
inverted: true
- delayed_on: 50ms
- delayed_off: 50ms
on_multi_click:
# 單擊:開螢幕 + 重設倒數
- timing:
- ON for at most 1s
- OFF for at least 400ms
- text_sensor.template.publish:
state: "button_01_single"
- switch.turn_on: sw # 開螢幕
- script.execute: oled_off_timer # 重設倒數
- delay: 2s
state: ""
# 雙擊:關螢幕
- timing:
- ON for at most 1s
- OFF for at most 399ms
- ON for at most 1s
state: "button_01_double"
- switch.turn_off: sw # 關螢幕
- delay: 2s
state: ""
# PZEM-004T V3 – 電壓/電流/功率/頻率/能耗
- platform: pzemac
energy:
name: "${device_name} 110V Energy"
- multiply: 0.001 # Wh → kWh
unit_of_measurement: kWh
frequency:
name: "${device_name} 110V Frequency"
voltage:
name: "${device_name} 110V Voltage"
current:
name: "${device_name} 110V Current"
power:
name: "${device_name} 110V Power"
update_interval: 6s
modbus_id: modbus1
# 每日電量統計(自動歸零)
- platform: total_daily_energy
name: "${device_name} 110V Energy Daily"
power_id: PZEM004T_Move_POWER
accuracy_decimals: 3
- multiply: 0.001 # W → kW
# 昨日電量(由 on_time 自動更新)
name: "${device_name} 110V Yesterday Energy"
unit_of_measurement: "kWh"
accuracy_decimals: 2
icon: mdi:power
# Uptime
name: "${device_name} Uptime Sensor"
# 字型(你已確認 arial.ttf 已放在 ESPHome 目錄內)
font:
- file: "arial.ttf"
# OLED 顯示 SSD1306(最佳化後)
display:
- platform: ssd1306_i2c
model: SSD1306_128X64
address: 0x3C
pages:
- id: page1
// 時間
it.strftime(64, 0, id(font1), TextAlign::TOP_CENTER,
"%Y/%m/%d %H:%M", id(esptime).now());
// 功率
it.printf(64, 38, id(font1), TextAlign::BASELINE_CENTER,
"%.0f W", id(PZEM004T_Move_POWER).state);
// IP 位址
it.printf(64, 56, id(font1), TextAlign::BASELINE_CENTER,
"%s", id(tcp_ip_address).state.c_str());
# Script:OLED 自動關閉計時(已最佳化)
script:
# 倒數關閉 OLED
- id: oled_off_timer
mode: restart
- delay: !lambda 'return (uint32_t)(id(oled_timeout_sec) * 1000);'
- lambda: |-
# OLED Reset(I2C 重置)
- id: oled_reset
- lambda: |-
id(my_display).setup();
# Text Sensors(IP / Buttons / Uptime)
# 顯示 TCP/IP(顯示在 OLED)
return { WiFi.localIP().toString().c_str() };
# Button 狀態
icon: "mdi:light-switch"
return {};
# Uptime 轉字串
icon: mdi:clock-start
update_interval: 113s
int seconds = (int) id(uptime_sec).state;
int days = seconds / 86400;
seconds %= 86400;
int hours = seconds / 3600;
seconds %= 3600;
int minutes = seconds / 60;
seconds %= 60;
char buffer[32];
sprintf(buffer, "%dd %dh %dm %ds", days, hours, minutes, seconds);
return {buffer};
# WiFi Info Sensor(多提供一組 IP,給 HA 用)
name: "${device_name} IP Address"
icon: "mdi:ip-network"
# Interval:若螢幕亮著,持續重置倒數
interval:
- interval: 60s
- if:
lambda: 'return id(my_display).is_on() && !id(oled_off_timer).is_running();'
